Beko GNEV221APB not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko GNEV221APB not working
  • #94321
    stuartlearmonth
    Bought a fridge freezer secondhand. Apparently was working but not working after delivery. Left gases to settle overnight then plugged in all day but did not get cold. Compressor hums then clicks off after a few minutes. Any advice?
    #457012
    Re: Beko GNEV221APB not working
    well compressor is not starting for some reason.
    it goes like this.
    you switch on at the mains, thermostat realises fridge is too warn and applies power to compressor, you hear the compressor hum which proves power is getting there but it does not start. As the compressor wont start it draws more current than it should, The overcurrent safety device on the motor detects this and shuts off the power with a click. After a few minutes the overcurrent device cools down and reapplies the power. the motor fails again and the power is shut off with a click
    short and long of it is it can only be 2 things
    1 motor start circuit problems. On some models they use a capacitor which can fail and it quite cheap
    2 compressor failure so its scrap
    stuartlearmonth
    Hi Dave
    Thank you very much for answering my query, it has helped.
