short answer no
the fan does not help the heat process it just cools the compressor
its a fridge circuit with the evaporator and the condensor after each other in the air circuit of the dryer. the only heat in the system is waste heat from the compressor
Done the diagnostic test humidity sensor plate has come up faulty I assume this is located around the front plate bearing housing. not sure as to what it would look like
