Beko HJA6100 Freezer Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko HJA6100 Freezer Problem
  • #77351
    briathlon
    Hi all
    Posted this in the wrong forum originaly :boops:
    I replaced the fan in this unit about 4 months ago and everything has been fine, however I got called back out to it yesterday because the freezer part is icing over big time and the ice maker has stopped working, apparently the ice maker had stopped working before it started icing over, does anyone have any ideas about what would cause this problem. Thanks.
    Brian
    #401919
    Seamy
    Re: Beko HJA6100 Freezer Problem
    Drain channel at back/bottom of evaporator is blocked up more than likely, think theres a modification kit to stop this happening, check defrost heaters, fan etc
    Think this one also displays error codes.. Look in display & if theres an “!” showing in display then theres a fault code stored
    #401920
    briathlon
    Thanks very much for the quick reply, any idea how to read the stored fault codes, i am totally unfamiliar with this unit. Cheers
    #401921
    SAMURI
    If you take the cover off on the module at the top on the underside is the list of fault codes.
    Bob
