Beko HNI64401AT Induction Hob
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko HNI64401AT Induction Hob
  • #100302
    Hollytree_Technical
    Product No: 7757186320
    Serial No: 19-102658-12
    Hi all
    I have been to look at this induction hob today after it went bang and confirmed that one of the IGBTs on the power board had failed, I am going to try repairing the module for the customer first and if not replace it but noted that this unit is barely 2 years old.
    I had a look at the pans that the customer is using and they do say that they are induction compatible but they look like they are a composite pan of the style which Rangemaster say not to use as they shorten the lifespan of the hob. Does Beko have any tech bulletins on this and is there any other service info available for them.
    Thank you
    Jem
    #480057
    for a start they have a 2 year warranty if registered and its integrated
    will look for tech
    manual emailed
    Hollytree_Technical
    Thanks Dave
    Unfortinatley I don’t think that they registered it (put in by kitchen fitters with the rest of the kitchen) so if I can’t mend the power board then they may be looking at over £200 in parts (ouch!).
    Jem
    #480060
    looked up main board
    part no 662000111
    connect £122
    aswo £93.01
    Hollytree_Technical
    It will also require the filter board as it has blown the fusible link.
    Jem
    #480062
    pics in the service manual show fuse clips there to add a fuse if link breaks. Have seen this on other makes so could probably get the fuse value from other manufacturers. all you would need then is the solder in fuse clips
    seem to remember rangemaster did it from the training at last conference
    Hollytree_Technical
    Adding fuse clips and a fuse is part of my plan for repairing this hob, I think that it is only the IGBT that is blown on the hob though I will change the rectifier as well which will hopefully be a much cheaper fix for them.
    Rangemaster use a 20A fuse – funnily enough I have to change one of their boards tommorrow for a communications problem.
    Jem
