Beko Induction hob making weird crackling sound.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko Induction hob making weird crackling sound.
  • #98778
    Tomek
    Hi. My first post here.
    Just over 2 years ago I bought “Beko QSE224X Black & Stainless Steel Single Multifunction Oven & Induction Hob Pack”. Today the induction hob started to make weird cracking sound. I recorded a small sample of it. It is still working, but I am afraid that it will have to be replaced soon.
    [video=youtube;aISTi2bFTAU]https://www.youtube.com/watch?v=aISTi2bFTAU&feature=youtu.be[/video]
    Is it still safe to use it? Humming and cliking sounds are fine but this crackling is a bit worrying.
    Thanks for help.
    #473777
    you have nit changed your pans or anything like that have you ?
    Tomek
    I am still using the same pans
    #473779
    is it all rings ?
    Tomek
    The sound is on all rings
    #473781
    from what i can see there is one main board on this unit
    in a lot of induction hobs they use one board for 2 rings so if the noise was only on 2 it would point to that board.
    in your case its most likley that board
    as a long shot remove the terminal cover and check the mains wiring screws are tight
    Tomek
    OK. Cheers.
    #473783
    Tomek
    Switched the cooker fuse off. Removed the oven. Jiggled a wee bit the cables to check if they are tight – they were. Switched the fuse on and the hob doesn’t make the crackling sound any more (on all for rings)! To be honest I have no idea what was wrong but I think that simple switching fuse off and on again would fix the problem. Thanks!
    https://i.ibb.co/Z6LVqs2/picture.jpg
    Update: The problem came back.
    It has stopped making noises. Don’t know what’s going on to be honest.
    #473784
    Tomek
    #473785
    could have been something virbrating and by moving it you have stopped it
