Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko integrated dishwasher
- This topic has 9 replies, 3 voices, and was last updated 4 years, 9 months ago by
adv.
June 23, 2021 at 3:15 pm #99712
adv
ParticipantModel din15r11 hi fokes when switch on at plug ie mains .. display bleeps and flashes once .then goes dead any ideas? Am thinking the PCB board?
June 23, 2021 at 5:20 pm #477523Hollytree_Technical
ParticipantCheck the door switch and as I think that this is one with the main module in the bottom of the machine then also check all of the wiring in the door hinge, you may need to give each wire a good tug as I had a similar machine where 7 out of 15 of the wires in the door hinge had broken inside the sleeving which meant that they looked intact but wernt.
Jem
June 23, 2021 at 9:35 pm #477524adv
ParticipantHi .it’s only a year old .so still under warranty .I was going to get involved as old customer . beko being a complete pain in arse .. wanting proof of purchase ..gave them it .the tried to Palm off saying it was a graded machine . obsolute joke ..I was on phone to AOL who I bought it from .and customer too .raging at their customer service .. shocking
June 24, 2021 at 1:49 pm #477525adv
ParticipantHollytree_Technical wrote:Check the door switch and as I think that this is one with the main module in the bottom of the machine then also check all of the wiring in the door hinge, you may need to give each wire a good tug as I had a similar machine where 7 out of 15 of the wires in the door hinge had broken inside the sleeving which meant that they looked intact but wernt.
Jem
How did you fix the wires ? A new complete wiring harness ? Be a nightmare job that ? And just putting bullet connectors on them .is a bit iffy now .. remember you used to get the old whirlpool harness wires ‘with connection grimps on both ends they were great ..don’t think you can get them now ?
June 24, 2021 at 2:22 pm #477526electrofix
Moderatorcomplete harness is les than £20 on connect
1758060600
June 24, 2021 at 2:52 pm #477527adv
Participantelectrofix wrote:complete harness is les than £20 on connect
1758060600
Mmmm how long it take to trace where every wire goes tho ):(
June 24, 2021 at 4:56 pm #477528Hollytree_Technical
ParticipantAt the time the harness was ou of stock so I managed to ease a bit of slack into the hinge and then used solder and heatshrink to reconnect them.
Jem
June 25, 2021 at 3:43 pm #477529adv
ParticipantAre right where can you buy heat shrink these days ?
June 25, 2021 at 3:53 pm #477530adv
ParticipantI see you can buy heat shrink quite easy must say never used it much
.only times was when changing the old aqua valves on the Bosch neff dishwashers .it came with couple .do you just use a lighter jem .or you got a proper heat gun ? 🙂June 26, 2021 at 12:36 pm #477531Hollytree_Technical
ParticipantI either use a heat gun or just rub the shaft of the soldering iron against it, just keep the iron moving and it won’t be a problem but you will need some quite small heatshrink to begin with as they are very thin wires.
