On a wash load it fills, it will not turn, the time counts down a couple of minutes the everything stops.
The time stops counting down.
The time colons continue to flash then after a couple of minutes the pump starts to run then stops.
This continues until it is switched off.
On spin exactly the same, not turning ,the time stops, the pump runs after a couple of minutes for about 20 seconds. Repeats
Anyone have any ideas? Motor PCB?.
