Beko Model CF5713AP not Cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko Model CF5713AP not Cooling
  • #96217
    Mike_Bates
    The Fridge part of my Beko Fridge Freezer is not cooling below 10º. The Fridge is about 6 years old. It was bought in the UK but is now running in a villa in Spain. Outside Temp is about 34º. An article linked to this Forum says that the Fridge temp should be 1-5ºC. Have I identified a cooling problem or am I just paranoid? If it´s a problem what is the most likely cause and resolution?
    #462709
    with those sort of outside temps the unit may struggle. Not sure if the units Beko would sell in Spain would be more powerful to cope with the extra heat
    make sure there is plenty of space all around the unit to help it getting rid of the heat
    also the number of times you open the door and where you place the thermometer can change the readings a lot
