Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Beko no go
- This topic has 18 replies, 3 voices, and was last updated 15 years, 5 months ago by
madrat.
October 14, 2010 at 7:50 pm #57991
madrat
ParticipantOur ageing Beko DE 3431 FW has suddenly died on us, it takes in the water and then nothing, it wont circulate, no noises, no flashing lights, nothing. I have to then hold in the start/stop button to drain it.
any ideas ?
serial number is 5023790011259October 15, 2010 at 7:03 pm #333012Seamy
ParticipantRe: Beko no go
Circulation pump motor seized most likely.
October 15, 2010 at 7:32 pm #333013madrat
Wow that went quick. Worked then the next time seized, didnt think they could do that so fast.
October 17, 2010 at 4:27 pm #333014madrat
I really, really need some advice on this before I part with cash. 😕
I have taken the motor out and tested it with a multi meter.
With the meter set to 200 ohms I get the following results.
Between the red & white wires I get 77.2 ohms
Between the brown & white wire I get 45.2 ohms
Between the red brown wires I get 122.2 ohmsThe motor is free and can be turned by hand.
The resistance between the connections on the heater are 30.5 ohms
There is no resistance between the terminal of the capacitor on the motor.
Is the motor shot or is it something else?
Please help.
October 17, 2010 at 8:39 pm #333015iadom
ModeratorRe: Beko no go
That does not compute…
Between the terminal and what?
October 17, 2010 at 8:41 pm #333016madrat
between both terminals, am I testing it wrong?
October 17, 2010 at 9:15 pm #333017iadom
Between both terminals of what, the terminals on the capacitor or between the capacitor and motor terminals. ❓
Either way a capacitor is cheap enough to try in any event, just get one of the same rating and give it a whirl.
October 18, 2010 at 4:01 pm #333018madrat
Participantboth terminals of the capacitor.
October 18, 2010 at 4:25 pm #333019madrat
can I bypass the capacitor just to see if it is that ?
October 18, 2010 at 5:14 pm #333020iadom
Definitely not, just buy a new one and stick it in, they are dirt cheap and it sounds as if yours is faulty.
October 18, 2010 at 5:20 pm #333021madrat
opps. 😕
did try it and still no go, so have ordered a new motor for £70. Condenser not listed on any web site, and the lowest call out cost was £47.
October 18, 2010 at 5:26 pm #333022iadom
It won’t run without the capacitor, thats what it is there for, to kick the motor into operation.
If you look on the side of the capacitor there will be a uf rating, they are bog standard parts as long as you get the correct value.
A new one should cost under a tenner.
Loads of them HERE
You would be mad to spend £70 on a motor before trying a capacitor, but then you did choose your own username. 😉
October 18, 2010 at 5:31 pm #333023madrat
ow well to late now. Order placed with Whitegoods
:rolls:
is 5-6 years old so a new motor might do it good, not that there was anything wrong with it anyway, but I bet the brushes are a bit worn by now.
October 21, 2010 at 1:04 pm #333024madrat
:sadder:
New part came but still dead.
Looks like a new dishwasher.
Defiantly another BEKO
Dose anyone want to buy a new wash motor? cant return it.
October 21, 2010 at 3:40 pm #333025iadom
Was that a typo or were you deliberately letting everyone know you really are mad. 😉 😆 8)
