Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko no heat.
- This topic has 13 replies, 3 voices, and was last updated 13 years, 10 months ago by
madrat.
May 28, 2012 at 4:33 pm #69684
madrat
ParticipantA friend has a Beko WMA1512 that is not heating the water, how can I tell if its the heater or thermostat that’s at fault?
May 28, 2012 at 5:59 pm #375669Martin
ParticipantBeko no heat.
Unplug from the mains then use a test meter direct onto the suspect components.
May 28, 2012 at 6:44 pm #375670madrat
ParticipantRe: Beko no heat.
Thanks, I take it I will get a resistance from a good part and open circuit from a failed component.
I am also getting conflicting info from different web sites as to part number. Some are saying 2863701600 others say 2863401000 they both look the same to me and I cant find a number on the original part.
May 28, 2012 at 7:56 pm #375671Martin
madrat wrote: I cant find a number on the original part.
Components don’t have part numbers stamped on them. What “part” do you refer to anyway?
May 28, 2012 at 8:01 pm #375672madrat
the heater element. According to the some sites the number is 2863701600 but according to other sites the WMA1512 dose’nt use this one, it needs 2863401000. So I’m a bit confused.
May 28, 2012 at 8:14 pm #375673Martin
I should say you’re confused…..the heater is 2703371000 and available here on this website….Go for it! 😀
May 29, 2012 at 6:12 pm #375674madrat
Thanks, I have another question. I have today checked the heater and thermostat with an ohm meter and obtained the following results. With the meter set at 20k ohms the heater reads 0.02 the thermostat 6.99, however there is no voltage at all being supplied to the heater, so is it something else? 😳
May 29, 2012 at 6:33 pm #375675kwatt
KeymasterRe: Beko no heat.
Yup. 😉
Could be….
- A wiring fault, possibly a break
A pressure switch fault
The heater contacts on the timerAny of which requires a bit of digging on your part to narrow it down I’m afraid. the good news is that’s a very basic machine so it shouldn’t take too much to figure it out.
Does it advance through the programs though as, it should stop at the heating phase if there’s a problem there?
May 29, 2012 at 6:33 pm #375676Martin
madrat wrote:however there is no voltage at all being supplied to the heater, so is it something else? 😳
Main circuit board bu$$ered by the sound of it then! Is there a skip anywhere near you?
May 29, 2012 at 7:16 pm #375677madrat
It goes through all the programs just fine?
What would you suggest?
May 29, 2012 at 7:31 pm #375678kwatt
Checking. 😉
It’s the only way but, those cheap range Beko’s are known for module/timer issues. If it is, I’m with Martin on it.
May 29, 2012 at 7:37 pm #375679madrat
OK I’m fine checking wiring and program terminals but how do I check pressure switch?
May 29, 2012 at 7:44 pm #375680kwatt
Continuity across the terminals while you’ve got pressure on it.
May 29, 2012 at 7:47 pm #375681madrat
Great thanks
