Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko No power
- This topic has 20 replies, 4 voices, and was last updated 5 years, 11 months ago by
rolf.
May 12, 2020 at 5:21 pm #97608
rolf
ParticipantHi.
I’ve got a Beko Washer dryer WDJ7523023W…….Prod code 71615420000.
Started with no power, nothing lighting up. Changed main board down below and it now lights up and you can change the programmes but it just beeps when you press start. Changed door lock still the same. I assume the board is programmed part number 2437301140. Thinking it must be the new board. Any advice would be appreciated. Thanks.May 12, 2020 at 6:51 pm #468620electrofix
Moderatorwell i get
2437301141
May 12, 2020 at 7:27 pm #468621rolf
ParticipantThat’s strange I got my part number from mediator connect. Do you mind me asking where you got yours from. Thanks
May 12, 2020 at 7:29 pm #468622electrofix
Moderatorbeko Tech
give me 5 will copy it
May 12, 2020 at 7:36 pm #468623electrofix
ModeratorMay 12, 2020 at 8:00 pm #468624electrofix
Moderatorhave emailed you the service manual
May 12, 2020 at 8:01 pm #468625rolf
ParticipantBloody hell I think your right. I’ll get onto them tomorrow and see what they say. Typical its out of stock.
Think you may of saved my bacon eagle eyes.
I’ll let you know the outcome. Thank you.May 12, 2020 at 8:06 pm #468626electrofix
Moderatorhave you looked at the old board as it sounds like a failed power supply chip
did one today on a hotpoint, slug shorted the power suuply out result dead board. One chip, one resistor and a diode and all working again
May 12, 2020 at 8:19 pm #468627rolf
ParticipantIt looked as clean as a whistle from what I could see. I’ll have a closer look when I go back.
Thanks for the heads up but I don’t do much repair work on boards apart from the odd cap or dry joint.
Might have to start !!May 12, 2020 at 8:36 pm #468628electrofix
Moderatorlook for a low value resistor normally 40 to 100 ohms if its open circuit let me know and i will talk you through it
you cant lose anything its broken now
May 27, 2020 at 9:35 pm #468629rolf
ParticipantRepaired board sorted it. Thanks Dave.
May 27, 2020 at 9:56 pm #468630electrofix
Moderatorbril
no probs
June 18, 2020 at 8:16 pm #468631Micky 32
ParticipantI went to 2 of these today with the exact same fault no power and both 18 months old. Digging on the net it’s usually a diode on the board ( D7). Low and behold on both of them the diode has shorted. Getting some tomorrow to try it.
June 18, 2020 at 8:54 pm #468632electrofix
Moderatorif the diode is failing may be worth looking at spec and uprating it
June 19, 2020 at 7:41 pm #468633Micky 32
ParticipantYep put a 2a one instead of the 1a .
