Beko not turning, belt OK and resistor
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko not turning, belt OK and resistor
  • #97087
    Monkeyboy44
    Hi all,
    The wife left the filter out last week, it ran for about 20mins then stop turning.
    The belt is fine, I changed the resistor still no joy.
    She lights up and when you press start button, you can hear the motor but it doesn’t spin.
    I’ve tried to manual turn drum but it doesn’t move. (can/should you be able to manually)
    Any ideas before intake it to the tip?
    Thank you
    #466071
    Model number ???
    Resistor…….do you mean capacitor?
    You should be to turn the drum by hand with moderate force.
    #466072
    Monkeyboy44
    Sorry, kids underfoot…
    Beko DSV64W
    And it was the capacitor..
    Apologies
    Cheers
    #466073
    Monkeyboy44
    Just tried the drum manually, with huge force it moved about 2 inches and made a horrible ‘screeching’ noise!? Could the motor have seized?
    #466074
    could be drum or the motor you need to take off the belt to find out
    Monkeyboy44
    FIXED!
    slipped the belt off…. Manually span the motor and a a dirty old sock fell out!
    Wife in doghouse but a result!
    Thanks all
