Beko ODF 22300 No heat/fan
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko ODF 22300 No heat/fan
  • #98850
    dazl
    Yesterday our main bottom oven stopped working (top oven/grill fine) . The switch to select fan/light etc is working but when the next switch to select temperature is used nothing happens eg no heat/fan.
    I’ve tested element (whilst fitted and removed) and get a reading of 30 ohms
    As always really appreciate any advice -Ive had previous help earlier this year with the top oven!
    #474030
    kaibart
    Well you say the switch is working and element has continuity have you checked you have power to the element or fan motor, other thing is the clock set that would be the 1st thing to check
    #474031
    robdeb1985
    Hi I had this happen to me not that long ago and the way it resolved itself was to switch all power to the oven off via the main switch and left it for about a min or so then switch power back on and set the clock and it all worked fine again. Not saying it will work for you but maybe worth a try.
