Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Beko OIF21300B (single oven)
- This topic has 11 replies, 5 voices, and was last updated 10 years, 5 months ago by
rocker.
October 30, 2015 at 6:11 pm #86529
rocker
ParticipantCalled today, found fan blade hitting the circular oven element, the blade clearance against heater when cold is about 1mm to 2mm. when hot clipping element, I was thinking of putting a smaller blade on fan.
As anyone come across this issue and can advise of best option please. JohnOctober 30, 2015 at 6:39 pm #432047johnnyj
ParticipantRe: Beko OIF21300B (single oven)
I’ve done that a few times with comebacks, JJ
October 30, 2015 at 6:57 pm #432048Lawrence
Change fan motor ,blade and element
October 31, 2015 at 10:33 am #432049rocker
Thanks for your reply Gents. John
October 31, 2015 at 1:58 pm #432050Seamy
Lawrence wrote:Change fan motor ,blade and element
Found that a belling fan blade does the job, let me out anyhow on one occasion.
October 31, 2015 at 3:58 pm #432051rocker
Seamy, do you know the part number please.
November 2, 2015 at 6:50 pm #432052Seamy
081581800
if you look at picture of this common fan motor, the fan blade can be used to let you out of a hole, not as big & wont catch on element.November 2, 2015 at 8:16 pm #432053rocker
Cheers Seamy, have a spare one in car.
January 7, 2016 at 10:22 am #432054Tom
I’ve got an oven with this problem, fan blade catching the element.
It is clearing the newly replaced element but only just.
The motor needs replacing too but is supplied without the circulation fan blade.
Noticed Seamy’s post with part number— 081581800.
I am finding that this comes as a belling fan motor but no circulation fan is shown.
I have belling circulation fan blades in stock but they are quite a bit smaller than the original Beko.
I ‘me wondering if you were referring to a blade a bit nearer the size of the beko but the there was an error in the part number supplied.
Thanks in advance for any replies / comments.
TomJanuary 14, 2016 at 7:16 pm #432055Seamy
Tom wrote:I’ve got an oven with this problem, fan blade catching the element.
TomPart number refers to a common Belling fan motor that most Engineers would stock, it comes with a fan blade & fan motor, just use the fan blade out of the Belling box which is not as large & doesn’t run tight to element.
January 15, 2016 at 10:01 am #432056Tom
Thanks for confirming this Seamy.
I have the Belling motor & fan.
tomJanuary 15, 2016 at 11:49 am #432057Lawrence
The other thing to be aware of is the new fan motors have an earth tag on the bracket that isn’t used ,in some cases we have had a vibration through the back panel after fitting a new motor and fan.
Just remove the tag and it goes away -
