Beko OIF22100X Fan Motor Problems
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko OIF22100X Fan Motor Problems
  • #76471
    jontymox
    Good evening all,
    Wondering if anyone can help/advise on a problem with the above integrated oven?
    The customer reported that the above main fan oven was heating up, but the fan was not working.
    I confirmed that the fan motor was faulty, although it gave a good Ohms reading, full voltage was being supplied.
    However, having renewed the fan motor with a genuine replacement, things aren’t much better… the motor does spin, but slowly/sluggishly.
    Perhaps the new motor is faulty, or I am overlooking something?
    Any help much appreciated.
    Jon
    #398450
    Re: Beko OIF22100X Fan Motor Problems
    if the motor is free and you are applying full voltage then its ok
    some of these motors run slowly to reduce noise it could be normal
    jontymox
    Thanks Dave,
    I was a little concerned as the motor only runs relatively slowly.
    Your helpful remarks may well mean all is well… time will tell!
    Kind regards,
    Jon
    #398452
    Hi Jon,
    I had a quick look and it’s a pretty basic oven.
    The only things that control that motor appear to be the switch assay and there’s a safety stat in the back but, other than that there’s not a lot else to be wrong.
