beko oven
  • #81552
    delta01
    hi this oven model looks like (01 21300b ) wont do anything but time display lights up i don’t normaly do much with ovens generally but this is one i have in a rental property and is not that old can anyone help please thanks John
    #416981
    SAMURI
    Re: beko oven
    Have you set a time on the clock?
    it does not have to be the correct time but if a time is not set the oven will not work.
    Bob
    #416982
    delta01
    Re: beko oven
    clock set ok thanks
    #416983
    Re: beko oven
    delta01 wrote:clock set ok thanks
    Is it set on ‘Auto’ or on ‘Manual’?
    #416984
    delta01
    Re: beko oven
    not sure will check, how do you cancel if set on auto ?
    thanks
    #416985
    Re: beko oven
    delta01 wrote:not sure will check, how do you cancel if set on auto ?
    thanks
    I ‘ve no clue as that model number is not recognised. But the user manual will tell you how to set and cancel auto anyway. (Available on Beko website)
    #416986
    Andy jones
    Re: beko oven
    There are a couple of toc’s on most Beko cookers that are prone to going. If timer is ok ten probably one of those
    Sent from my iPhone using Tapatalk
    #416987
    delta01
    Re: beko oven
    thanks all will try your suggestions ,cant seem to download manual
    i got the actual model no its OIF21100W
    #416988
    delta01
    Re: beko oven
    thanks Andy you were right the toc was o/c do they just fail or could the thermostat need replacing ? do you have a part no for the toc model no
    OIF21100W please
    thanks again john
    #416989
    Andy jones
    Re: beko oven
    Bekbe263410017 on qualtex. Check cooling fan is ok
    #416990
    delta01
    Re: beko oven
    thanks i noticed the rear fan is intermittently noisy top one seems ok
    thanks again
    john
    #416991
    delta01
    Re: beko oven
    sorry to bother you again Andy do you have the part no for the rear fan motor please i cant tell which is the right one on qualtex site
    thanks
