Beko oven igniter issues
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko oven igniter issues
  • #101185
    MarkP32
    Hi all
    We have an old Beko (c 10 yrs) dual oven cooker model BDVG592S that started misbehaving a couple of days ago.
    The bottom oven wouldn’t light but you could hear the ignition sparking. I took a look and it seemed to be that the spark current was shorting across two wires before it reached the spark plug itself. There are two wires, one bare and one insulated (brown). I disconnected the oven from the mains and moved the bare wire away from the insulated wire to stop the arcing and now the oven works. I just need someone in the know to let me know if this is OK or if we need some kind of repair to ensure safe operation?
    #483725
    its not dangerous but it sounds like you may need a new wire at some point as the insulation has broken down
    i have checked and an enginn
    eer wouldc have to replace the electrode and cable to fix the problem
    part is about £15 so not expensive
