Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › beko oven not heating up
- This topic has 14 replies, 4 voices, and was last updated 9 years, 9 months ago by
plumb1.
July 12, 2016 at 4:59 pm #88767
plumb1
Participanti have a beko OIF21300W Oven has stopped heating up. I have changed the element, still no heat. The fan works. I have taken the top cover off, and there are 3 wires going into the timer, blue, white and brown. i have power to the brown and white.
Think i have set the timer correct???
July 12, 2016 at 5:02 pm #439299plumb1
ParticipantRe: beko oven not heating up
just to add no power to the blue wire
July 12, 2016 at 5:47 pm #439300plumb1
i Have take the back off, when i turn the control knob to any setting there is power to the heating element, the fan at the rear is spinning fast and the fan on top of the oven is going round slowly.
July 12, 2016 at 6:13 pm #439301plumb1
Just to add i have tested the connections as stated above with a neon screwdriver, so maybe not accurate???
July 12, 2016 at 6:16 pm #439302Martin
Power to the element but what of the neutral return? If the cooling fan at the top is running slow then chances are the overheat thermal cut out has failed? Check that out.
July 12, 2016 at 6:19 pm #439303SAMURI
If you have power to the element then you will need to test the new element to check it is not faulty.
If the clock was faulty then the fan would not work.
Bob
July 13, 2016 at 8:43 am #439304Martin
lilyalvin wrote:It will help checking the system.
Many of your comments are vague and pointless in many of your posts. Please enlighten us by being a little more specific as to what you mean in this case? We’re striving collectively in trying to help the guy out here after all.
July 13, 2016 at 5:35 pm #439305plumb1
First of all, thanks for taking the time to reply to my thread.
Managed to borrow a multi meter, tested a few things, list below1- multi meter reading 4 ohms reading
2- Top fan 100 ohms
3- bottom fan 96 ohms
4-stat at top adj fan 0 omms, look this out and put a cig lighter flame on it, and heard it click on/open?
5- Element 36 ohms
6- Temp thermostat knob 3 between 2 black wires no readingI put the power on and tested for 240 v,
1- top and bottom fans 240
2-Thermostat turned off 240 between 2 black wires
3- thermostat turned on NO power between the 2 black wires but neon light on.When i turn the power back on, i have to reset the time, what is the Key Lock ? i make sure this is off, is that correct ??
July 13, 2016 at 6:37 pm #439306Lawrence
Check the neutral connections in your terminal block it sounds like when you have opened the rear panel you have disconnected a wire
July 13, 2016 at 9:00 pm #439307plumb1
I will take it out of the housing and strip it down and look tomorrow. But the grill still works, so maybe wiring ok ???
July 13, 2016 at 10:50 pm #439308Lawrence
Just because the grill element works it doesn’t follow that the fan element should
These elements are one of the simplest to fit and so long as you put the wires back on terminals in the same places it should work.July 16, 2016 at 1:28 pm #439309plumb1
Hi Lawrence
i have checked the neutral wires and they all seem ok, The oven stopped working before i disconnected anything
originally the oven stopped working, bought a new element and fitted it,as you say simple job, oven still not working.
got a meter and checked the old element and that is ok.1- multi meter reading 4 ohms reading
2- Top fan 100 ohms
5- Element 36 ohms
3- thermostat turned on NO power between the 2 black wires but neon light on.July 16, 2016 at 6:14 pm #439310Martin
Oven selector switch might just be your problem here?
July 18, 2016 at 8:45 pm #439311plumb1
Hi Martin, i think you could be correct ??? when i strippped it down again on staurday i did notice there where small electric sparks(arching maybe a better term) when i turned the oven selector knob round. Seemed to be coming from the contacts.
is the part available on whitegoods?
July 19, 2016 at 6:20 am #439312Martin
plumb1 wrote:is the part available on whitegoods?
I would imagine so yes, take a look why not. 😉
