Beko Oven OIF 22300 X element wouldn’t turn off.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko Oven OIF 22300 X element wouldn’t turn off.
  • #75364
    Johannah4756
    We have recently had to replace the element on our Beko oven, model as above. This solved the problem, but the fan seemed to be running slow after the repair.
    Now, some 2 months down the line, the element wouldn’t switch off even though all the dials were turned off. The light went off and the fan stopped, but the oven didn’t cool.
    I turned the oven off at the wall switch, and when I switched it back on, the display flashed and it made a constant beeping noise. Nothing I pressed would stop this and nothing now works.
    Can anyone help as to what the issue may be and whether it can be a DIY fix ( with a little guidance)
    Thanks.
    #394683
    QUICK FIX
    Re: Beko Oven OIF 22300 X element wouldn’t turn off.
    is any of the tags of the element touching the back casing off the applaince
    #394684
    Johannah4756
    No I don’t think so.
    I don’t remember there being any tags on the element when it was fitted. We will check this tomorrow to make sure though.
    #394685
    Specialist01269
    Hi: By tags he means the terminals that the electrical connections are attached to on the element.
