Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › beko oven thermostat is different
- This topic has 9 replies, 2 voices, and was last updated 6 years, 1 month ago by
Carrie Digby.
February 18, 2020 at 10:43 am #97212
Carrie Digby
ParticipantHi there,
we have a beko oven (odf2230x) and we have ordered a replacement thermostat and we are struggling to fit it as the one in the oven has got 4 connectors, and the new one has only got 3??
we have looked on various sites and this same new thermostat is the one for our oven, but they are all the same.
please can anybody advise? how are we supposed to fit it?
thanks so much!
February 18, 2020 at 11:29 am #466575kwatt
KeymasterWhere did you order it from, what part number was supplied? Also can you check the model as odf2230x is not recognised?
February 18, 2020 at 11:33 am #466576Carrie Digby
Participantsorry its odf22000x and the part is the main oven thermostat 9i think the part number is 1771095OH.
there is a note on the beko site to say “The manufacturer has updated this part and the one received may be different to that in the image with the tag layout different but it is compatible”
but obviously this doesn;t help us fit it 🙁
my hubby has taken it into a parts place and they are confused too.
February 18, 2020 at 11:41 am #466577kwatt
Keymasterodf22000x also not valid, sorry.
It is really important to get that mode correct or use the product code from the rating plate of the oven around the door opening.
February 18, 2020 at 11:42 am #466578Carrie Digby
Participantso sorry….odf22300x
February 18, 2020 at 11:48 am #466579kwatt
KeymasterOkay, I’ve no clue what you’ve been given or from where so I can’t tell you if it’s correct or not. That’s not a real part number as many retailers will hide the real part numbers so you can’t price compare.
The correct thermostat used for both large and small oven in that appliance is this one:
https://shop.ukwhitegoods.co.uk/263100015-beko-cooker-oven-thermostat
Or this compatible that’s cheaper, same thing though really:
https://shop.ukwhitegoods.co.uk/ot118-compatible-cooker-built-in-oven-thermostat
There are only earth and two spade terminals or should be on the original version. The new one may have three on it and it’s simply a case of figuring out what ones make and break on temp if they’re not marked, which they often will be with numbers on the thermostat body.
February 18, 2020 at 12:14 pm #466580February 18, 2020 at 12:15 pm #466581February 18, 2020 at 12:16 pm #466582Carrie Digby
Participantthanks – I have tried to upload photos of our current one but it won’t let me so I have tried the links above to share with you…
February 18, 2020 at 12:20 pm #466583Carrie Digby
ParticipantThe photo I have uploaded shows the 4th connection coming from the selector switch. All the replacements only have 3 connectors, live neutral and earth, where does the 4th connection go on the replacement stats??
