Home › Forums › Public Support Forums › Spare Parts Help › BEKO part where selector switch inserts into
- This topic has 11 replies, 3 voices, and was last updated 4 years, 5 months ago by
pc__ukwhitegoods.
October 11, 2021 at 10:49 pm #100121
pc__ukwhitegoods
ParticipantBEKO OVEN :: BIE23304XPS
Hello,
I’m desperately looking for the bit where the oven selector switch inserts into. Connects to the front panel.
Is that something you can help locate?
Any ideas would be greatly appreciated.
Cheers
October 11, 2021 at 11:05 pm #479315kwatt
KeymasterIt’s a part of the timer unit, that whole assembly comes as one part.
If I remember I’ll look it up in the morning for you but expect it to be the best part of £100.
October 11, 2021 at 11:07 pm #479316electrofix
Moderatoram struggling with the model
can you check model and have you got the commercial code ?
October 11, 2021 at 11:17 pm #479317kwatt
KeymasterI found it Dave, I do that all day long. 😉
October 12, 2021 at 7:29 am #479318electrofix
Moderatorkwatt wrote:I found it Dave, I do that all day long. 😉
knew it was prob part of the timer
had a customer in yesterday, came in asking for a knob but when he showed it to me the stalk of the selector was sticking out of it
October 12, 2021 at 8:20 am #479319kwatt
KeymasterFound it, it’s this unit in that oven:
https://shop.ukwhitegoods.co.uk/267440119-beko-oven-timer-unit
October 12, 2021 at 6:59 pm #479320pc__ukwhitegoods
ParticipantHi – thanks for looking into it – yes, that’s the correct unit – thanks a million!!
thing is, having to purchase the whole unit just for the knob shaft feels a bit overkill.
Perhaps we can go about it another way.
I do have the broken pieces – the shaft snapped in two courtesy of my adorable son – I tried a melt-the-plastic approach to putting it back together with no luck… perhaps because it is not plastic. It actually carbonised the thing.
Can you recommend an adhesive that will hold the two parts together and that is heat resistant?
October 12, 2021 at 8:35 pm #479321kwatt
KeymasterI doubt any adhesive would hold it, temporarily maybe but not for long.
October 12, 2021 at 8:41 pm #479322electrofix
Moderatorkwatt wrote:I doubt any adhesive would hold it, temporarily maybe but not for long.
agree tried with a few things but never as strong as original
you have 3 options
new board
new oven or
try to find some plastic bar and make one ( you have nothing to lose by trying apart from time )Dave
October 12, 2021 at 10:38 pm #479323pc__ukwhitegoods
Participantwhat about CT-1. That’s pretty strong, but not sure it’ll take the heat. Any thoughts?
October 12, 2021 at 11:10 pm #479324electrofix
Moderatorsome plastics glue well others dont
ct-1 is just a superglue in essence. for that to work both surfaces have to be clean and flat and more important is the plastic has to ahere well to it
this is info you only get by trail and error
but in the end I think its unlikely to suceed
what you really need is a scrap oven you can take it off but thats rare. have already scanned ebay
October 13, 2021 at 9:24 pm #479325pc__ukwhitegoods
Participantthanks for your help – what I’m going to do is drill into one of the halves, fill it with an epoxy glue and insert the shaft into the hole hoping it’ll cure solid enough to hold. After all, it only needs to turn, no massive force or pull is applied. If that doesn’t work, then I’ll have to go for the whole panel. Thanks for the ideas. cheers.
