Beko pcb
  • #103323
    euro
    Beko PCB 2858195000, anyone know if this part number is still live or has it been replaced by another number.
    Andy
    #492664
    have you got thr model number and the serial number for the machine its off ?
    Aswo list the above part no but has a lead time of approx 5 to 6 weeks
    Whats wrong with the board ?
    euro
    Its a WTL84141W S/N-23107474-09 , if you remember Dave last year the problems i had with this model not unlocking the door at the end and you advised changing the heaters on them which worked fine. This ones got same problem again and even with heater replaced still the same. It does the wash no bother but at end when it should unlock all the happens on of the led lights just keeps blinking and going round the display and even leaving it for awhile dont make any difference, only way to unlock door is to switch it on and it opens straight away
    Andy
    #492666
    ok cant get into Beko at the mo. Hopefully just a site down
    if i type the model number into Aswo i get main board part no 2858195330
    but you have 2858195000
    both board listed on aswo but one is available on connect
    will see if i can get back into Beko prob tomorrow as we often find board number changes by serial no
    ok from Beko tech correct board with that serial is 2858195330
    connect have stock
