Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko pcb repair
- This topic has 12 replies, 3 voices, and was last updated 5 years, 1 month ago by
kaibart.
March 5, 2021 at 3:04 pm #99228
kaibart
ModeratorHi just wondering what compenent has blown on this pcb and where i can purchase 1 from
March 5, 2021 at 3:12 pm #475533kaibart
ModeratorPhoto of pcb
March 5, 2021 at 3:20 pm #475534electrofix
Moderatordid you take a pic slightly more left. want to see if there is anything printed on the board and poss where it connects from
have you got model of machine ?
March 5, 2021 at 5:05 pm #475535kaibart
ModeratorLwf27441w 7162741200 serial 17-101003-07
March 5, 2021 at 10:18 pm #475536electrofix
Moderatoris this writting here, if yes what does it say ?
March 6, 2021 at 12:58 am #475537Hollytree_Technical
ParticipantMy suspicion based on its location, orientation and the fact that the part number on the label comes back as a motor control PCB is that it may be the remains of a small fuse possibly in line to the transformer.
Like Dave said the designator next to it should confirm it but if not then a photo of the rear of the board would help with tracing it out.
If it is as I suspect a fuse then I would suggest checking the motor output semiconductors for shorts as they don’t blow like that for no reason.Jem
March 6, 2021 at 1:00 am #475538electrofix
Moderatoragree there thats a big bang so other things have blown as well
March 6, 2021 at 6:33 pm #475539kaibart
ModeratorHere is a photo of the other side of the pcb and the part that is blown. 1 other question how do you test the diode on the beko w/d pcb
March 6, 2021 at 6:38 pm #475540electrofix
Moderatorput a multimeter on diode test
put the leads on the diode one each end note reading if any
reverse leads
you should get a reading one way but not the other.the blown board, by the look of the tracks I agree with jem, looks like it may be a fuse
March 6, 2021 at 7:09 pm #475541kaibart
ModeratorSo new pcb then is it i cant see anything else wrong any burn marks
March 6, 2021 at 10:23 pm #475542electrofix
Moderatorwhat worries me a little is what that fuse supplies
you could try a trick
find a 240 lampholder and an old style 100W lamp
put 2 wires on the lampholder and solder one wire to either side of where the fuse came out
the lamp is now a sort of fuse. if you turn on and the lamp goes very bright then you know it would have gone bang
what am interested in is does this fuse also serve the motor. if the answer to this is yes then fitting a new board will just make it pop again
cant trace from the photos where the live goes to when its left the fuse
March 7, 2021 at 6:28 pm #475543Hollytree_Technical
ParticipantIt looks like the fuse goes to one of the switch contacts on the relay, my guess is that the other side of those switch contacts go to a bridge rectifier and then the motor output drivers (the drivers will be mounted on the heat sink, possibly also so will be the bridge rectifier).
The relay will probably be being used to allow it to switch off most of the circuit board when it is in standby.
I would suggest that at least some of the output drivers will be dead and the bridge rectifier. You may be lucky and find that it had just been heavily overloaded or a voltage spike etc took it out but I would check the motor carefully before you think about reusing it.Jem
March 8, 2021 at 6:02 pm #475544kaibart
ModeratorSo update on this fitted a motor pcb and all is working well can only assume it was overloading
