I’ve been out to the above, It has an additional pump which the tech info refers to as a loading pump- can somebody tell me what this does please?
regards Darrell
Don’t you just love Turklish,I wonder if its an inlet valve ? as the water is the only thing I can think of that the machine loads with apart from the obvious such as crockery etc
What are the symptoms Darrel ? we have had a couple ofthese new inverter circ pumps fail,symptoms are low drone with no pressure
Hi Lawrence, it drains and fills as normal then no circ pump- had it out and the impellor’s free,hard to test the live in/out with my probes. If I can find a spare terminal I will make a live test rig- pump is 220-240v. Going back with the test info soon that Dave supplied. The extra pump looks exactly the same as the drain pump-what’s confusing me is partmaster have an extra pump that looks the same and it’s listed as a pre wash pump from my terminology- that would kind off make sense if Beko call it a loading pump? thanks
