BEKO QOM 246B
  • #93495
    gswainyboy
    Hi all.Probs with the oven.Have got replacement Bi Metal button thermostat but cannot see where it fits.All I can see is temperature sensor (Replaced) and thermal cutout.Strangely though.,the cutout fixing centres are the same as stat.does this replace the cutout ? Thanks for advice in advance.Graham
    #454535
    Re: BEKO QOM 246B
    What part number is the stat you have bought ?
    gswainyboy
    Re: BEKO QOM 246B
    Hi Dave.Thanks for replying.Pt no on the new stat is 263410017.Problem is I have had back and top off and can see cut out switch and the heat sensor which protrudes thro into oven and which I have changed
    thanks
    Graham
    #454537
    Re: BEKO QOM 246B
    shows this in manuals re that part number
    gswainyboy
    Re: BEKO QOM 246B
    Hi Dave.Lids off again.This is Pt no 161471.052 which I have removed.So does the other item 263410017 replace this although they look different.I thought this was a safety cutout,not the oven stat although fixing centres are identical. 😕
    Thanks for your patience
    Graham
    #454539
    Re: BEKO QOM 246B
    if you are looking at a number on the stat then that is the part number from the manufacturer of the part which is no Beko. so there is no cross reference to this
    the part number goes as per picture
    gswainyboy
    Re: BEKO QOM 246B
    Sorry Dave,tried to post pic but too large and not sure how to make file smaller,
    Graham
    #454541
    gswainyboy
    Re: BEKO QOM 246B
    Sorry Dave but really confused.The item I have removed looks exactly like Pt No 300180155. The part on the pic you sent earlier looks like a 210110549 fitted to a bracket.This is the button stat that I have but this is not fitted on our oven that I can see
    Regards
    Graham
    #454542
    gswainyboy
    Re: BEKO QOM 246B
    Also Dave,would there be a temperature sensor (Item 587) on your pic, which I have already replaced, as well as a thermostat.
    Cheers
    Graham
    #454543
    Re: BEKO QOM 246B
    the picture used covers a few ovens. when I looked up the breakdown manual is does not seem to have this bracket on this model
    you will see part has 2 part numbers listed but in the part listing only one of them are there
    so on some ovens they fit 2 of these stats but not on yours
    as for the look of the 2 stats just different manufacturer but do same job
    dave
    #454544
    gswainyboy
    Re: BEKO QOM 246B
    Hi Dave.Looking on eBAY and found a seller (SUDS ONLINE) with item BEKO EDF223000X.This is exactly the same as I took off but it then shows 2 more pics of a later version (Which I have bought) and apparently the design has been changed which would explain the confusion.Am now going to fit this and will let you know the result,
    Cheers
    Graham
    #454545
    gswainyboy
    Re: BEKO QOM 246B
    Thanks yet again Dave.Fitted new stat,had already fitted temp. sensor and gets to temp ok when on no.2 (takes longer to reach) but not no3 when fan element should also be working.I have a feeling that fan element has gone so that when she puts it on 3,which she always does,the fan is running but element is not heating.Will buzz out element tomorrow but I have found in the past that if an element (kettle,bulb or cooker) has blown trip switch goes but didnt this time.What do you think ?
    #454546
    Re: BEKO QOM 246B
    most of the time switch is ok
    depends on how element blows and how it is connected
    fit lots of elements where that is all that has failed its less common for the switch to go as well especially these days where the fitting of RCD’s trip out the power
