I have a beko de2542 slim line dishwasher. The main recirculation pump seems to have a burnt out winding. No continuity across the terminals. I can see the blackened wiring.
I’ve seen identical looking pumps on eBay thoat are rated 125w. The one on mine is 90w. Is the pump supplied by the pcb and if so will the 125w pump draw too much and cause the pcb to fail?
No live testing is recommended!
You’re theory of filling the bottom won’t work, this dishwasher counts water in via a flowmeter so it won’t go on unless flowmeter detects 4 litres has passed through.
Have you checked the fine blue wires to flowmeter in loom of door are’nt goosed??
Have never seen one with burn’t out motor.
