Beko s512w cooker
  • #65210
    crockett
    Hd all,called to look at a beko s512w cooker,the lady said the oven is not cooking fast enough ,over two and a half hours cooking a chicken and it wasn’t cooked properly and other food likewise.Elements are ok and the thermostat is cutting in and out ok.There are two elements in the oven compartment,one for the grill and one for the oven which come on seperatly.Should both elements be working when the oven is on or is it correct that the outer element is only supposed to be on when the oven is on.Can anyone advise on this please.
    Thanks.Crockett.
    #359523
    Beko s512w cooker
    What about the base element?
    #359524
    crockett
    Re: Beko s512w cooker
    thanks r600a,Ididn’t see a base element havn’t worked on this type of cooker before is it under the the oven floor or how can I access it please,
    #359525
    steve1
    hi
    you will find the base element has blown, you have to remove the back panel to gain access
    #359526
    crockett
    Thanks again for your help i’ll have a look tomorrow and let you know how I get on, much appreciated, crockett.
    #359527
    crockett
    Hi all again,checked out base element thanks to r600a, this element is also working fine,I’ve come to the conclusion that this cooker oven just possibly dosn’t work as fast or efficiently as this lady is used to, she is not long in the house and the previous tennant has told her that the only thing bad about the house is that the cooker oven is verry slow. Perhaps this is the case with all Beko s512w cookers, if anyone out there has had the same experience or can throw any light on the subject it will much appreciated. Thanks again to everyone especially r600a.
    Crockett.
    #359528
    Seamy
    Top element listed as 800W, lower 1100W, grill 1500W, take it from that that outer grill is only used during oven function. I’ve come aacross this problem before & all you can do is advise customer to preheat oven until oven light goes out before putting in food & calculating cooking time, they’ve probably been used to a fan oven before.
    #359529
    crockett
    Thanks Seamy,I’ll advise the customer of that,yesterday she said she’d have to put the christmas dinner on now to have it cooked on time.
    Regards to all, Crockett.
