Beko SCG180W Gas Cooker – Urgent advice required
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko SCG180W Gas Cooker – Urgent advice required
  • #19030
    javedsaleem
    I need help.
    The cooker has been unused for 6 months. I now go to use it, however, the oven comes on, but does not stay on. As soon as you release the switch, it goes off. I not sure whether to replace the Thermo Coupler or whether it is the something else.
    Can you help please
    #181420
    Dave_Conway
    Re: Beko SCG180W Gas Cooker – Urgent advice required
    Legally this must only be repaired by a Corgi registered engineer, please try the repairs@ link below for one or the Corgi website here:
    http://www.corgi-gas-safety.com
    #181421
    javedsaleem
    thanks for the reply
    It is being looked at by my Brother – he is a Registered Corgi Engineer – he thinks it may be the Bypass in the oven thermostat, but he is not sure – can you help furthr
    thanks
    #181422
    javedsaleem
    can you also tell me where I can get a technical manual for the cooker or download it for free ??
    #181423
    You will not be able to get a “manual” as you mean, at best you’ll get a parts list and a blow-out diagram. Maybe a wiring schematic if you’re really lucky.
    By-passing anything is highly inadvisable normally, on gas it’s a total no-no and your brother should know better if he’s CORGI.
    javedsaleem
    He’s not bypassing it !!!!!! – he says that he believes it may be the Thermostat, but he is not sure – he said the bypass screw (or something) is in the thermostat
    #181425
    It’s almost certainly the thermocouple. The gas valve in a domestic cooker should almost never have to be touched or adjusted.
