BEKO Showing E08
  • #101518
    An ex squash playing mate has just called round asking if I have any ideas about his washer.
    Beko WTG841 B2W. Showing error code E08 when set to wash programmes, says the drum will rotate on spin.
    Any ideas?
    #485060
    kaibart
    The error code failure is on bekos website water inlet valve/pump running continuously, solution check water valve, valve triac faulty
    #485061
    Thanks, it’s the same as the old E8 ones for the WMA models by the looks of it. He says it starts to fill for a second or so the cuts out. Seems to be pointing to a pcb fault.:(
    #485062
    kaibart
    Might be worth checking wiring to valve I’ve had one break doing the same fault
    #485063
    Will pass the message on.;)
