Beko side by side fridge AP930x temperature query
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko side by side fridge AP930x temperature query
  • #85671
    RHrepairs
    I am currently reconditioning a Beko American fridge, i have it plugged in for over a month now and the front display is reading -18 and 4 degrees. Everything appears ok.
    I have a thermostat in the fridge and my question relates to the temperature on the different shelves of the fridge. In the veg compartment it is 0-1 degrees. In the middle it is 4 degrees and in the top it is reading 7-8 degrees. Is this normal?
    On top of this i have put the thermometer in to the diffuser and all im reading is 11 degrees is this normal? Or would i need a new diffuser?
    #429234
    SAMURI
    Re: Beko side by side fridge AP930x temperature query
    Is the Fan inside the freezer working ok.
    Bob
    #429235
    RHrepairs
    Yes it is. Freezer is working properly. Does it sound like the fridge isnt functioning properly. I ran the service test and no faults came up. When you open the fridge door you can hear the diffuser flap close
    #429236
    SAMURI
    If the fan is working then it is most likely working normally.
    If the defuser and sensor in the defuser fails it stops cooling or freezes in the fridge.
    It is warmer in the defuser as it has a heater to stop the flap freezing.
    Bob
    #429237
    RHrepairs
    Thanks Bob, that would explain the diffuser. Is it natural to be 0-1 degree in the bottom of the fridge. I put a bottle of water in the bottom of the fridge it would be frozen after a few days. If i put it in the middle its fine
    #429238
    SAMURI
    It should not freeze at the bottom.
    You need to check the vent at the bottom as it sounds like the air from the freezer is leaking back into the fridge at the bottom vent.
    Bob
