This is just under 2 yrs old…… cx opened door by mistake then afterwards had the problem
You can select any setting fine, the lights do what they should…. press start but nothing happens, no clicks, no pump just nothing!!
Do the cancel procedure, lights do what they should BUT still no sounds or funtion at all
Took door off, checked for broken wires and loose connections to pcb but its all good —- Gut feeling is pcb because there’s no sound or clicking from it
Any ideas please?
