beko spins immediately
  • #24046
    abbots
    hi guys,
    WMA10W
    Sn. 05-161544-11
    7105185000
    washing far too fast and if you put it on a spin it goes full speed straight away.
    i suspect the moter tacho is faulty, has any one else come across this?
    if so can you get the tacho on its own or is it a complete moter job?
    thanks.
    jk
    #200356
    bzz67
    Re: beko spins immediately
    elecrue mediator shows a tacho coil with metal shell part number 371202204.
    #200357
    abbots
    cheers bud
    #200358
    maltheviking
    It hasn’t got a shorted triac on the board by any chance? 😉
    #200359
    abbots
    possible, would that effect only the motor speed or any other part of the program?
    no obvious sign of any problem with PCB.
    jk
    #200360
    maltheviking
    Generally it would run up to full speed on wash as well as spin, triacs are easily changed if you know what you are doing, if you are not sure then send the board away for checking 😯
