Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BEKO Tacho Magnet Needed!!!!
- This topic has 7 replies, 6 voices, and was last updated 14 years, 9 months ago by
redreloaded.
July 2, 2011 at 12:22 pm #63712
redreloaded
ParticipantAfternoon all,
As a result of a previous post I was helped to successfully diagnose the fault with my machine which turned out to be a shattered tacho magnet, excellent I thought a quick fix, until trying to get hold of one of the little buggers.
Its not the tacho coil I’m after, which seam to be widely available but the actual tacho magnet that fits to the end of the drive shaft of the motor, I cant seam to find one anywhere! So I wondered if anyone has an idea where I may be able to get this else it will have to be a whole new motor.
Its for a BEKO WM5120W washing machine.
Many thanks,
Steve
July 2, 2011 at 4:38 pm #354624electrofix
ModeratorRe: BEKO Tacho Magnet Needed!!!!
as far as i am aware complete motor only
have not found another one that will fit yet unless someone else knows better
July 2, 2011 at 5:17 pm #354625washtronics
ParticipantRe: BEKO Tacho Magnet Needed!!!!
i phoned qualtex that contacted beko and they said it is available as a spare part
July 2, 2011 at 5:58 pm #354626electrofix
i hope you are right Washtronics
but Qualtex dont list it connect dont list and the Beko tech site says noting about the magnet only the coil
one long shot if anybody has both motors lying around
hoover list a tacho magnet for performa and quatro range will it fit? even if shimmed and glued?as i say its a long shot but it needs to be tried
July 2, 2011 at 11:31 pm #354627odom
Easiest and cheapest way is to go down to your local dump, bound to be a couple of Beko machines there. Pay one of the blokes £10, take the machine, get the magnet off then get your £10 back by taking the machine (with the motor separated) to a scrap metal merchant.
July 3, 2011 at 5:12 pm #354628Martin
BEKO-DUMP-MAGNET…….how true, how appropriate.
July 4, 2011 at 8:35 am #354629electrofix
@ Martin
May 31, 2012 at 7:49 am #354630jackalltrades
Thanks to this and a previous post, i managed to trace the fault to the broken tacho magnet.
As they’re not available, I’ve glued the magnet together onto the motor shaft with two part epoxy metal. Still working. So far so good! -
