Is there a problem with the bearings or belts. I’ve had 3 of these drum, jammed take the drum out,can’t see why it jammed.have I missed something.thank,s Gordy 29
I usualy change the front bearing pads when i change the belts as the 1st one i did snapped the belt after in about a fortnight, changing the bearing pads at the same time on them since and i havent been called back once.
