Beko Tumble Dryer : DCU8230 : No Pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko Tumble Dryer : DCU8230 : No Pump
  • #83613
    neilsukwg
    Voltage to pump is 30 volts
    should be 240
    can only be pcb or am i missing something?
    #423266
    Seamy
    Re: Beko Tumble Dryer : DCU8230 : No Pump
    Trace cable back from pump to board, check output there to see if you get correct voltage, check float switch and loom is all I can advise.
