Beko tumble dryer DTGC8011W (7182482670)
Home Forums Trade Technical & Spare Parts Forums Beko tumble dryer DTGC8011W (7182482670)
  • #98122
    dunston
    This dryer has a random high pitch squeal. Its something running quickly. I’ve heard It once however by the time I had took the side off the noise had stopped.
    Has anyone had a problem with the drum rubber wheels? I could hear the pump and that seemed OK.
    #470959
    have you checked the idler pulley ?
    https://shop.ukwhitegoods.co.uk/4922…elt-pulley-kit
    Also found info below
    dunston
    Never had a problem with the pulleys. Will check it. Thanks
    #470961
    dunston
    The dryer was manufactured in July 2018. The modification worked a treat. I would never have found that fault. Thanks Electrofix 🙂
    #470962
    no probs m8
    glad to help
    its one of the reasons we keep pushing manufacturers to make this info available to professional engineers. you would not have a hope of finding this without the bulletin
