Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Beko tumble dryer not heating up
- This topic has 9 replies, 2 voices, and was last updated 5 years, 1 month ago by
Paigntontim.
March 6, 2021 at 3:11 pm #99235
Paigntontim
ParticipantHi all,
i have a beko dhr73431w heat pump tumble dryer. This morning I turned on as normal and found this is not heating up.
i put this into test mode and come up with error codes
01 & 02
i have tested the water pump & the overflow switch all good ,
Also, can not hear the compressor kicking inI’m stumped any advice would be great
Also when I opened the sides there was no capicitors but starts fine, I was lead to believe there should be 2?? 1 for starting and the other for the heat pump?
thanks
tim
March 6, 2021 at 3:22 pm #475564electrofix
Moderatorerror 1 is a door open fault
error 2 is overflow sw error
if you have looked at overflow sw there is no reason you should be getting E02
March 6, 2021 at 3:34 pm #475565Paigntontim
ParticipantThanks dave for your reply
tested the overflow sw on a multimeter and all seems fine. In your option replace the switch?
thanks
March 6, 2021 at 3:44 pm #475566electrofix
Moderatornot without more checking
i assume the board thinks its full or the like
do a resistance test across it both closed and see if you get any reading when its open on a high scale
March 6, 2021 at 4:03 pm #475567Paigntontim
ParticipantThe panel is normall , no warning lights on,just checked the switch closed is no continuity open .3,
thanks Dave for all your help so far
March 6, 2021 at 4:11 pm #475568electrofix
Moderatorcould the test mode be coming up with historic codes so no longer relavent
DaveMarch 6, 2021 at 4:19 pm #475569Paigntontim
ParticipantThis is what I thought
any ideas how to clear these codes?
thanks tim
March 6, 2021 at 5:45 pm #475570electrofix
Moderatorno on test mode the unit displays the last 5 fault codes so its likley your codes are historic
also in the test proceedure you will not get past stage 10 without short circuiting the sensor plate within 10 secs. The compressor test is on stage 13
March 6, 2021 at 8:17 pm #475571Paigntontim
ParticipantJust went into the test mode and stopped at number 6
nt 01
nt02 error codes now, any ideas how to fix this one? Or is this the same ones as before?
thanks timMarch 6, 2021 at 10:03 pm #475572electrofix
Moderatorthey are not error codes
NTC is a thermistor the display should be showing values of Nt1 and Nt2
manual states
If NTC and Voltage Error occurs, Err:or appears on the display and the service test cannot
be passed to the next stepsDave
