I’ve got a Beko tumble dryer in the workshop, one of the rear stats has blown so I have replaced the stats and element.
The dryer still does not heat.
I have checked the value of the NTC in the door front and the value is ( 14.47 K Ohms ) I do not know what the correct value should be, so i was wondering what the working value is.
Did you find this was an ntc? only I have same model to repair where element resistance checks out ok at module end, tried module but still no heat.
Martin.
