Beko Tumble Dryer small belt DSV64W
This dryer has a small belt about 10 cm in diameter that goes to the motor pulley and then to a larger pulley, whitch then the drum belt fits on, to drive the drum.
Anyone know how to stretch this belt and fit it. I have tried all standard methods.
Put the belt in Boiling wtare, stretched it for 24 hours used screwdrivers to try and manipulate it on the pulleys.
The problem is the two pulleys are so close together you can’t slip anthing around the pulley like a socket or pipe like the usualy way of fitting tight stretchable belts.
Anyone managed this.
