Beko TZDA524F no longer freezing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Beko TZDA524F no longer freezing
  • #98236
    dab996
    Hi, we have a Beko TZDA524F used as a spare freezer which sits in our garage and the door wasn’t closed properly resulting in a total defrost and loss of all food. After removing contents, we shut the door but now it no longer freezes. We have since unplugged and left for a few hours to see if this would reset but when plugged in, the green light comes on with temperature showing (Min = -18) and then it flicks off and on every few seconds with a faint clicking noise. It has done this before and I can’t remember what we did to get it to freeze but we did get it working. I have tried the fast freeze button which when depressed flashes -27 with a beep and amber indicator but when released disappears reverting to green light on flashing -18 and then off every few seconds. Condenser at rear bottom of freezer is warm to the touch.
    Any ideas appreciated.
    Thanks,
    Any ideas greatly appreciated.
    #471472
    does sound a bit like a board fault
    dab996
    Would that be worth repairing/replacing?
    #471474
    possibly
    board part no should be 4308600685
    with the age of it it may be worth trying the board power supply first. on the board is a large blue capacitor probably 1uF x2 type. This give the board its power and they are cheap so wortn a try if you can solder
    dab996
    Thank you.
    #471476
    dab996
    Is there a recommended place to buy the part as it’s not available from the spares section on this site?
    #471477
    if its the capacitor then ebay or amazon
    if its the part then look around for someone who has stock
    dab996
