beko tzda627fw e4 fault code
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum beko tzda627fw e4 fault code
  • #67450
    CHOOSY
    got a beko TZDA627FW whit a E4 fault. I think this is the auto defrost is not working is this right. If so what part is i need and where is situated.
    thank you stephen :eeek:
    #367477
    CHOOSY
    Re: beko tzda627fw e4 fault code
    FOUND OUT THAT E4 FAULT MEAN THAT IT HAS FAILD TO START 4 TIMES IN 1 HR. TO RECTIFY THIS U NEED TO REPLACE THE Evaporator Bottom Assembly KIT AND DEFROST SENSOR
    #367478
    If you need to change the evaporator you need to regass the fridge freezer which isn’t a DIY job I’m afraid.
    But, your information is a bit incorrect according to Beko.
    E4 is a defrost heater error. The defrost time has gone on four times inside one hour and then the heater failure error is displayed.
    I would have thought that would indicate a fault with either the defrost sensor or the defrost heater and that replacement of the evaporator was not required.
    HTH
