beko vented dryer pulley
  • #84763
    delta01
    hi fitted a small belt with extreme difficulty recently, i noticed on Qualtex site you can get two very similar pulley and belt kits part no’s
    bekbe 492204403 or 492204404 the second one being twice the price, someone suggested replacing the pulley and belt was an easier option can any one clarify which pulley i shoul d use thanks John
    #426679
    Seamy
    Re: beko vented dryer pulley
    03 belt kit is for vented dryer, 04 belt kit is for condenser dryer. I think you can get the belts on their own without the pulley.
    #426680
    if you had posted you model number etc i could have looked unit up on Beko tech site
    @Seamy
    whats the difference pulley size or belt or both ?
    delta01
    i fitted the belt only as i said with great difficulty about 7 attempts using a plastic tie on pulley unfortunatly i cant remember the model no. sorry but i guess all the later vented ones are the same. but as i mentioned someone suggested replacing both pulley and belt was easier, so i wondered if they reduced the pully diameter slightly
    #426682
    Andy jones
    have found it easier to replace both
    #426683
    delta01
    thanks for all your responces
    john
