Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. This topic has 4 replies, 3 voices, and was last updated 12 years, 5 months ago by laurenceuk. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts October 28, 2013 at 5:09 pm #77828 laurenceukParticipant Hi, Selected spin, when start pressed the drum goes immediately into fast rotation and pump operates, all for about 3 seconds, then stops and goes to end of prog. I checked tacho on motor – ok. Any thoughts welcome, thanks. Laurence October 28, 2013 at 6:07 pm #403546 bazza500Participant Re: Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. Had a couple. Module replacement fixed it. October 28, 2013 at 6:57 pm #403547 laurenceukParticipant Re: Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. Thanks Bazza October 29, 2013 at 10:20 pm #403548 oakleyjoParticipant Re: Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. Also, check the wiring between the tacho and the control board. I had this problem and the wire had broken off in the back of the motor connector. Cheers, Jon October 29, 2013 at 10:38 pm #403549 laurenceukParticipant Re: Beko Wash Mach. WM7335 Anyone Had This Fault Before?.. thanks Jon Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
