Beko wash814dw E06 fault
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko wash814dw E06 fault
  • #99869
    Dmcilmoyle
    Is it possible to get a copy of circuit diagram of main control board for Beko Wash814dw. Motor fault. Motor checks out fine.
    #478237
    if by circuit diagram you mean the full circuit of the board itself then you wont get it
    the best you can hope for is the wires to and from the board
    E06 is listed as motor traic short circuit. The triac will be mounted on the heatsink on the board
    Dmcilmoyle
    Thanks Dave, hopefully will be able to get part number of triac off the component before I replace it. I will try replacing it and hopefully it’ll sort the problem. I appreciate your help.
