WDIX752300 DRYER PROBLEM. on dry it starts for about a min can hear the fan then it stops and door unlocks. When i took the lid off the stat had tripped but didnt work after reset, Any pointers? tested all the dryer parts
Dop
I’m having a similar issue with one of these. Original fault was no heat so reset TOC. Then dryer would run for 1 min and end the program. fitted NTC (for some reason called ‘door Ntc’) worked fine for a week now the TOC has tripped again. waiting for customer to arrange to get back to it.
