beko washer fault
  • #38525
    abbots
    hi
    WMA641S
    06-100480-11
    washer switches on
    door interlock operates
    start light comes on
    spin/end light comes on
    pump cuts in for a few seconds then nothing, start light and spin/end light stay on and it wont do anything.
    this happens on all programs.
    any suggestions?
    thanks.
    john
    #259187
    PGS
    Re: beko washer fault
    Have you checked water valves
    #259188
    abbots
    no i never , as it didn’t do anythink on spin, drain etc i didn’t think the water valves would be the problem to be honest.
    will the machine not fill hot/cold/rinse or spin if a valve is o/c ?
    jk
    #259189
    PGS
    Pressure system fault perhaps.
    #259190
    abbots
    sorry,
    i thought i did when i said it wouldn’t do anything ,
    and it happens on all programs.
    jk
    #259191
    Checked filter/pump?
    Mike.
    #259192
    Martin114
    Motor down to ground.
    #259193
    abbots
    thanks guys,
    i’ll go and have another look.
    j
