Beko Washer (No Heat)
  • #53642
    subs
    WMA 10W 06-156523-12
    This machine is not heating. The element and thermistor check out ok.
    When you select a hot wash, for example a 90o cotton on the timer, it rotates round to a 40o wash then starts. If you select a 60o wash it clicks round to a 30o wash then starts. It still does not seem to heat on the lower temp programmes.
    Any ideas?
    Subs
    #316726
    Re: Beko Washer (No Heat)
    Advance from start position is quite normal. If the heater and the ntc check out, it’s the timer/pcb unit at fault.
