Beko Washer WMA1512W
  • #22787
    johnnyhoz
    Tumbles with a medium to full load but does not kick into spin,
    with small load spins ok, has anyone come across this
    johnnyhoz
    #196155
    cab
    Re: Beko Washer WMA1512W
    motor brushes me thinks!
    cab
    #196156
    johnnyhoz
    Thanks Cab, Already checked them they have plenty of meat left on them the machine is only 14months old
    john
    #196157
    kevvie
    It could be an unbalanced load. Therefore, out of balance switch will kick in and cause no spin. Customer could be overloading.
    #196158
    Hi Kevvie, welcome to UKW.
    Kevvie is right IMO, that’s the most likely explanation. Could be a faulty PCB though detecting an imbalance when there isn’t one.
    Flyman
    Out of balance detection can become more sensitive due to slightly worn belt or if inner drum is catching door seal . 🙂
    #196160
    jimca007
    could also be partially broken wire on motor plug extra weight pulls drum down stretches loom- no contact had a few of these with poor connections into motor plug
