Dont know if it’s been covered before but a number of complaints about Beko washing Machines burning smell when the door is opened after wash has finished. Memo from Beko requires you to change the door seal as it is rubbing on the inner drum, on the worst cases the complete tub has to be changed beacause the door seal has welded it’s self to the inner drum Beko range is the wma510 520 etc. Hope this helps some techs.
