Beko Washing Machine – dancing display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko Washing Machine – dancing display
  • #69657
    lyndy
    Got a customer with a Beko washing machine, WM74155LW, 7116641100
    The display is flashing on and off selecting programmes. Different LEDs alongside digital display are flashing for different programmes. Display flashing intermittently. Some programmes can be used, others not.
    Have run diagnostics and no error code shows up. Have checked continuity of motor and pumps etc. but nothing untoward. However, there is no sound to indicate the pressure switch is clicking on when the machine does start.
    Any ideas?
    #375525
    Seamy
    Re: Beko Washing Machine – dancing display
    I’d change the p.c.b, part num’ is 2826330551, theres a pressure sensor in it probably rather than a pressure switch & you won’t hear it click.
    #375526
    GPservice
    Ive had this before, was the PCB, just make sure motor is not sparking & brushes are ok as the one i had im sure was damaged by spikes from the brushes in the motor.
